  #1
Old May 8th, 2008, 06:54 PM
95century 95century is offline
Default 115 Yamaha engine problem???
Hello Everyone..I have a question to ask that hopefully some of you have dealt with or have experienced in the past. I have a 1995 115 Yamaha that will only idle and go to a max of 3000 RPM's. After you push the throttle down she bogs and then immediately stalls if not brought back below 3000 rpms? I checked the fuel filter and it is not clogged and I also replaced the Fuel Oil seperator with no improvement. New sparkplugs had just been put in along with a lower unit oil replacement. This sounds like a fuel issue to me but Im not sure. Should I take apart the carbeurators and clean them or do they make a spray that I can just run through them? Could it be the fuel oil pump?Thermostat problem? Impeller problem? I tightened up all the clamps on the fuel oil lines to make sure they were air tight...Any help would be greatly appreciated...its almost peak of striper season here on the east coast and this problem is killing me!....Thanks!
Steve
  #2
Old May 9th, 2008, 06:20 PM
rowboater rowboater is offline
Default Re: 115 Yamaha engine problem???
You might start with checking the fuel pump.Its a simple check and would rule out at least one potential source of the problem.I am pretty sure if you do a search of "fuel pump" it will give you a checkout as well as similiar symptoms your engines experiencing.Good luck I don't check the site regulary (thankfully my 1997-115 hasn't had many problems lately) but will check back to see the fix or try to help you out with some other ideas.
  #3
Old May 10th, 2008, 10:49 AM
Ray Neudecker Ray Neudecker is offline
Classic example of fuel restriction. There have been more posts on the cause and cure than any other subject. You need to start at the fuel tank and work forward until you find and cure before you blow the motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Problem with Yamaha 115 prolineez Yamaha & Suzuki Outboards 3 November 19th, 2009 11:45 AM
problem with Yamaha 115 prolineez Yamaha & Suzuki Outboards 3 August 2nd, 2007 06:38 PM
Paint Engine Cowling on 115 Yamaha?? bayhawk14 Yamaha & Suzuki Outboards 2 October 27th, 2005 06:26 PM
115 yamaha problem dzwear Yamaha & Suzuki Outboards 0 July 7th, 2002 04:06 PM
Yamaha 115 problem Laura Yamaha & Suzuki Outboards 4 April 18th, 2002 01:33 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
