  #1
Old May 7th, 2008, 09:49 PM
jonoman69 jonoman69 is offline
Default 1958 7.5 evinrude water pump???
Hi, I have a 1958 7.5 evinrude. I dont think that the water pump is working. First off let me make sure that I have this right the water gets sucked through the hole just above the propeller, and comes out the only other hole that is midway up starting at the bottom end. If I have that right, the water pump is in the lower portion correct??
  #2
Old May 7th, 2008, 09:55 PM
freddyray21 freddyray21 is offline
Default Re: 1958 7.5 evinrude water pump???
the water pump is in the lower section. Those motor need to be run a bit deep for them to pump right. The water pump is just above where the lower unit bolts to the leg.
  #3
Old May 7th, 2008, 09:59 PM
kk, but the water that has already cycled through, is exits through the
hole midway up , same hole as the exaust???
  #4
Old May 7th, 2008, 10:00 PM
HighTrim's Avatar
HighTrim HighTrim is offline
This is for the 5.5hp, but is virtually the same.
http://outboard-boat-motor-repair.co...ter%20Pump.htm
Here is another link that may help in the future. Again, is for a 3 hp in the example, but many of the principles are the same for that era.
http://www.maxrules.com/fixtuneitup.html
__________________
Chris
  #5
Old May 7th, 2008, 10:05 PM
CATransplant's Avatar
CATransplant CATransplant is offline
No. That is the exhaust relief outlet. Some water, mixed with exhaust will exit there. Most of the water however, exits near the prop, under water, along with most of the exhaust.
The relief hole is there to let exaust out when idling the engine. If it were not there, excess backpressure would probably stall the engine.
If there's some water, mixed with exhaust coming out of that hole at mid-leg, water is being pumped by the impeller.
If all the exhaust and water went out that hole, it'd be terribly loud.
  #6
Old May 7th, 2008, 10:10 PM
but if there is only one whole near the prop then were does the water enter????
  #7
Old May 7th, 2008, 10:19 PM
wildmaninal's Avatar
wildmaninal wildmaninal is offline
through the little plate on the side of the foot I believe. Here is a flushing adapter I built for my 5.5hp 59 Johnson.
__________________
1977 Challenger 15' Bass Boat with a 1978 85HP Evinrude (finished project but keep finding stuff to add to it)
Projects include: To many boats, to many outboards, and 1 I/O that I hope to be rid of soon.
  #8
Old May 7th, 2008, 10:22 PM
you mean the square thing???
  #9
Old May 7th, 2008, 10:28 PM
Yes. The square plate. The picture of my motor's foot shows the flushing adapter I built to put in place of the regular plate, the plate that goes there should have 4 holes that have scoops on them to scoop the water up.
__________________
  #10
Old May 7th, 2008, 10:34 PM
Quote:
Nothing short of genious, Wildmaninal; now I have to make one.
  #11
Old May 7th, 2008, 10:40 PM
Talking Re: 1958 7.5 evinrude water pump???
Thank you Freddyray. Mine is just a simple piece of aluminum with a brass fitting in it that I clamp a water hose to. I used the plate off of the foot as a template for the bolt holes. I drilled the hole for the brass fitting just so the fitting will screw right on to the aluminum plate, there is no nut on the back side holding it on. So far it works great, it might leak a little but that water has to go somewhere.
Of course you can add your own touch to it. Otherwise it is patent pending lol, just joking.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1958 Johnson Water pump replacement ewalden444 Johnson & Evinrude Outboards 2 April 26th, 2007 05:07 PM
1958 Evinrude Lark 35hp won't pump water jrw1295 Johnson & Evinrude Outboards 4 August 12th, 2006 11:19 PM
1958 Mercury28 water pump ser1177613 lmddmc Mercury & Mariner Outboards 1 November 15th, 2005 03:28 AM
1958 Evinrude Lark 35 Water Pump ?'s warstoryz Johnson & Evinrude Outboards 12 September 18th, 2005 04:23 PM
Need Water Pump for a 1958/1957 MK10 bobeecher Mercury & Mariner Outboards 2 February 14th, 2002 01:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
