Re: termites
being a retire building contractor, there is only one way to find the rest of the infested areas. start at point A, start tearing out following the trail. when the trails end. thats it. being in Florida, i know termites, intimately.
I have to agree with TD on this, the only real way to find them is see for yourself how far they've gone.
I had problem here with termites years ago, when I built the garage about 20 years ago I used all pressure treated wood and had the termite guys come out and pump the ground full of poison. It got rid of the termites for the time being, but soon after I had big black carpenter ants eating the roof beams and rafters which were the only non pressure treated wood in the building. After a year of fighting to get rid of the ants, and 12 rafters and one support beam later, they were gone, but about ten years ago I started to notice little sawdust piles again and found some soft wood down low, sure enough it was termites, they had eaten away nearly the whole one wall and all the studs as well as most of the floor before I ever saw a single sign. They ate the pressure treated wood and all. I again had the termite guy come out, and another $600 to kill them off and two years later now their back, this time eating the other side of the building. They've never touched the boats or the house yet, but they sure seem to have a taste for the garage. They've even eaten through 3/4" plywood that's been well oil soaked from years of motor work and greasy engines. To make matters worse, I also have a problem with skunks undermining the foundation as well, nothing has deterred them either, short of a shotgun, but the results of that would last months. A few of them though have actually become pretty tame or just bold lately, they'll walk right in and right between your legs and never bother you when your working out there, I've had one walk right up to me an stop, look and continue, then do the same on it's way back out, it sure keeps strangers away. Even the cat don't bother them anymore. Years ago I dug down deep around the whole building and buried wire mesh, but they chewed right through it and peeled open an access hole. The one morning there was at least 4 huge wheel barrels full of dirt at the entrance to the hole. It wouldn't be so bad but they keep digging right under the main door step, if they were out back where no one walked, I'd maybe let them be. You can here when there in there, they make quite a racket and I've even heard a few fights with other animals going on. The skunks usually win. The problem is living with the aftermath of the fight till the odor subsides.
