hi, have a 92 40 hp 2 carb mariner, runs great all the way to wot, but at idle it will 'chirp' at times and stall, pulled the carbs and cleaned well, carb cleaner, compressed air and wire through the jet stem holes, i held the carbs upside down, one float was level with carb body and the other was showing low of about 4 mm, these floats are not adjustable so just fit them back in, the air/fuel idle screws are out to about 4 turns from seated and still sneezes/stalls, could that one float cause all that or do i need to look elseware for a problem ? thanks for having a great forum
