  #1
Old May 7th, 2008, 02:59 PM
Evinrude4HP Evinrude4HP is offline
Default 1987 4 HP Evinrude - Help with water pump replacement?
Hi,
Evinrude Model: 44RCUD
S/N: B1374707
New to the forum. I'm a torpedo mechanic, and long time auto mechanic, but this is my first time doing ANY maintenance on an outboard marine motor. I was given this 4hp Evinrude by my father and it seems to be in great shape. I drained and refilled the lower unit with correct oil, and replaced the two sparkplugs which were pretty gunked up from lack of use/maintenance.
After replacing the plugs, the motor starts right up.
Unfortunately, I don't see ANY coolant water peeing from behind the head like with most motors. I plan to pick up the impellar replacement kit today and do the job.
A few questions for you veterans....
1. Where exactly IS the coolant water pee hole on this motor so I can check for clogs?
2. Am I removing the lower unit, or just the two bolts that secure the prop to the lower unit? If its the lower unit, where are those bolts located?
3. Also, is there a fuel filter screen within the carb?
Any help would be GREATLY appreciated.
  #2
Old May 7th, 2008, 03:35 PM
Xcusme Xcusme is offline
Default Re: 1987 4 HP Evinrude - Help with water pump replacement?
Quote:
Originally Posted by Evinrude4HP View Post
Hi,
S/N: B1374707
First off, Welcome to iboats!
1. Your motor doesn't have a 'tell tale' or pee stream. Water and exhaust is expelled from a small opening on the midsection behind a baffle cover. If you can hold your finger on the head , while running, for a few seconds, it's cooling. It's best to replace the water pump impeller anyway if you don't know for sure when the last replacement was done.. Document the date when you replace it and then you'll have a baseline on future maintenance.
2. Nope, leave the 2 bolts that secure the prop to the lower unit alone. Look for 2 bolts, one under the cavitation plate, the other forward nose of lower unit. Remove both.
3. No carb filter IN the carb. If you have intergral fuel tank, there's a filter screen in the tank, same for the external tank.
  #3
Old May 7th, 2008, 04:23 PM
Excellent. Thanks for the quick reply.
Heading out to pick up the kit now and I'll get started. Should I use any sealant with the housing bolt reassembly or the lower unit bolts, or am I better off with just anti-sieze?
PS - The motor doesnt get too hot (i.e. you could leave your hand on top of it as long as you wanted.) Could you explain more specifically where this: "Water and exhaust is expelled from a small opening on the midsection behind a baffle cover" is?
  #4
Old May 7th, 2008, 04:52 PM
Non-copper based anti-seize should be fine. The idle exhaust relief port is on the rear of the midsection. The port itself is covered with a port cover held on with one screw. This port relieves back pressure on the motor at idle and should spit both exhaust gases and cooling water at idle. When in gear and underway, exhaust from this port will lessen as the exhaust will be pulled through the midsection and expelled underwater along with the motors cooling water....
  #5
Old May 7th, 2008, 05:09 PM
Theoutdoorsman's Avatar
Theoutdoorsman Theoutdoorsman is offline
Since the motor has been sitting unused for an extended period of time, you are wise to change the water pump. Too, you might consider taking a few minutes to read a couple topics in the frequently asked questions forum concerning additional maintanence on your "new" outboard. Here's a couple links I think you will find most interesting. BTW....... Welcome to iboats!!!
http://forums.iboats.com/showthread.php?t=158076
http://forums.iboats.com/showthread.php?t=158086
Also, I'm not certain you have the parts diagrams for the outboard. If not, you can take a look at some exploded diagrams, complete with part numbers, here. If you look at the "gearcase" subfolder, you will see the exploded diagram pertaining to the water pump assembly..............
.........Click here............ http://www.brp.com/en-US/Related.Products/Parts.htm
Now....... Under the "Parts Heading" click on "Visit the site now".
Next...... Click on the green check mark in the box located in the top left hand corner and select "View Parts Catalogs"
Now....... Click on the "Go" button beside the box, again in the upper left hand corner of your screen, that says "Evinrude". (Johnson owners need to change this to Johnson from the drop down menu first)
Now...... Select the appropriate folders for your year, horsepower, and model number to view the parts lists and exploded diagrams. Here, you will find that subfolder containing the "gearcase" diagram that I spoke of earlier.
Good luck to you................................ALAN
  #6
Old May 8th, 2008, 08:47 AM
thanks to everyone for the quick helpful replies. I got it done in about 15-20 min last night. piece of cake. I noticed the new evinrude waterpump "pin" has changed to a plastic looking triangular instert....where as the original that I removed was a metal half-round pin.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Water pump 1987 6hp Evinrude sailorgeo21 Johnson & Evinrude Outboards 6 November 13th, 2008 12:50 AM
Water Pump replacement 1987 SPL 88 horsepower Evinrude outboard Motor B.autry4711A Johnson & Evinrude Outboards 9 March 17th, 2005 05:10 AM
Water Pump replacement 1987 SPL 88 horsepower Evinrude outboard Motor B.autry4711A Johnson & Evinrude Outboards 6 March 6th, 2005 04:13 AM
Water Pump replacement 1987 SPL 88 horsepower Evinrude outboard Motor B.autry4711A Johnson & Evinrude Outboards 3 February 26th, 2005 04:33 AM
Evinrude 90 Hp (E90ELEC) 1997 - Replacement of water pump len_b Johnson & Evinrude Outboards 4 February 21st, 2002 02:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
