Re: 1994 2858 Dual helm steering very stiff!
Well, pretty much no on all of those answers. It should turn easily from both the bridge and lower station. The only thing that would cause that problem is a cable issue. If you're somewhat mechanically inclined remove the cable link from the steering arm itself. With those removed try your steering that way. If still binding then the cables. If easy, then go to the transom and move the outdrive unit. One of the two will be binding - that will narrow it down to a 50 - 50 deal. With the power steering system you will not need to have the motor running at first. Do this with both the engine off and then again with it running. It is nothing more than a simple process of elimation.
Yea, it will be a little time consuming and it might take two able bodies to do it but at least you'll be saving $100.00 an hour over the marina's rate.
