Battery Switch Help
FL Boater
I recently replaced both trolling motor batteries and just relized my battery switch is not working on the 1 or both setting and only on the 2. Do I have somthing hooked up wrong.
bruceb58
Re: Battery Switch Help
Probably your switch.
If it was that 2 worked, "Both" worked and "1" didn't work, you probably have "C" and "2" backwards. No matter how mis-wired, the "both" setting would always work.
FL Boater
Thanks for the info, but that leads to another question. Is there a way to know for sure it's the switch before I take it out and replace it?
PondTunes
you could check continuity with a digital multi meter. The meter should read continuity between the common and #1 when the switch is on #1,
continuity between the common and #2 when the switch is on #2,
Nothing should have continuity when the switch is OFF,
Continuity to everything when the switch is in the BOTH setting.
harkawy
My Force 70 requires a "Make Before Break" switch to avoid blowing the rectifier when changing positions. Can you recommend one at a reasonable price and how can you test the functionality with a DMM?
PondTunes
They sell them right here on iboats! Popular brands are Perko, Guest & Blue Sea Systems. If you have one you are pondering changing you could look the model number up online to verify if it was a make-before-break, otherwise if you want to test it with a multi-meter you should be able to check continuity from position #1 to position #2... Turn the switch slowly and it should show continuity between the two posts for a second as you go from position 1 to 2 and vice versa... If you have a DMM with an audible continuity alarm it will make your job a little easier.
Looking up the switch is probably the fastest way!
Battery Switches from Iboats
harkawy
I have a Perko in my boat now. I guess I'll check it out to make sure that it is a make before break. If is isn't, then I'll buy one here.
Boatist
I agree with above but to check continuity with a multimeter you must disconnect the batteries from the switch or you will blow up your meter.
When in the Ohms postion can have no external voltage hooked up.
