Re: Overheat cutout on johnson 50 1988
is the motor being run in a large test tank or a barrel? if a barrel the water in the barrel will get hot from the exhaust. the exhaust, also interferes with the water pickup. there is a method to the madness of trouble shooting. start with checking the spark on both cylinders, check the compression, that motor will run on one cylinder. with it running in neutral, with insulated pliers, pull one spark plug at a time, and listen for a difference, if there is no difference, that cylinder is not working. if it dies, that cylinder is working, and the other isn't.
