ok, i have gotten my motor all the way ready...and the lower unit oil leaks out from where you detach th elower unit from the arm...i see in the kits that there is a speghetti seal...is this what needs to go on that area? when i bought the motor it didn't have it. i have my lower unit all the way apart now...and cleaned up the nasty smelling oil water mix...and i now have to redo the seals i guess...anyway, the area that the drive shaft...and the shift shaft come out of...the two holes...i am guessing that is where the O-rings in the kit go? how do i get that out? i was thinking a dowel rod...and hammer on it and hope for the best. i am not sure what is leaking, but i wanna be sure to replace all the seals. i also did a carb rebuld kit...and had some spare rubber o rings...not sure what those go to...i also had several left over oval gaskets...2 of them fit, but one fit a little better...i guess these parts might be extra because it is for several models. anyway... it took me forever to get that dang spring to hook to the needle valve for the gas to enter...the one that hooks to the float. i had to bend that thing for ever to get it to work right.
i also took the gear housing apart..and now i can't remember what the gears are supposed to look like when put together. i can't get it to sit in the gear housing correctly, and can't find an exploded view of one either
