I have posted about this problem last winter, but now that spring is here I want to bring it up again. 1972, johnson 20hp, electric start, long shaft. when I got is last fall it would start but not run for more than a few seconds and it would immediately die if you would give it any throttle, and make a gasping sound as it died. So here is what I have done. Compression is good, spark is good, COMPLETE carb kit installed, new low speed needle valve, new wiring, new impeller, coils look brand new, and I also cleaned the points with emery cloth. The motor ran really crappy until I cleaned the points with emery cloth, and then it seemed to run good in the tank for about 20 minutes. It was responsive at the throttle and idled pretty good. So I thought it was fixed and I put away until the ice came off of the lakes here in iowa a couple of weeks ago, and I put it on the boat to try it out and it runs just like it did last fall. I think about the only thing I have not done is replace the fuel pump. Someone told me they think it could be the fuel pump or the float sticking, just wanting more thoughts on this before I go buying more parts.
