  #1
Old May 5th, 2008, 10:13 PM
fatfred69 fatfred69 is offline
Default 1992 Mariner 200 Hp. Loss of tac signal !
Recent purchase of rig with a Mariner 200 Hp Carb engine, overall really great shape. Tact doesn't work. Traced the loss of signal to the grey lead @ voltage regulator module. Engine has dual systems. changed tact lead to other module connection. Worked for about 20 mins. then lost that signal! However the regulators outputs still look normal! Continuity checks to tact from engine module lead. Changed to new quicksilver tact,,,, no help!
I am electronically savvy and have some equipment.
Suggestions....recommendations? Thanks for any inputs!
fatfred69
  #2
Old May 5th, 2008, 11:44 PM
j_martin j_martin is offline
Default Re: 1992 Mariner 200 Hp. Loss of tac signal !
Usually the regulators go, and take the tach signal with them. I've had both fail on mine, one at a time. The early clear potted 5 wire ones are notoriously weak. The black potted 6 wire ones are a bit stronger. CDI is best.
Pull your battery down a bit, then disconnect the regulators one at a time. I'd be willing to bet neither one is putting out what it should.
hope it helps
John
  #3
Old May 7th, 2008, 12:21 PM
Angry Re: 1992 Mariner 200 Hp. Loss of tac signal !
John;
Really appreciate the input! As you know....you are exactly correct! I have followed this procedure and there is '0' output from the reg's! I also pulled the two yellow wires and am getting 28 VAC out! Not good! lol......
After closer inspection I find the reg's are the 'originals'....Hummmm! I have a pair of the CDI's on a Fed-X truck as we type!
Good boating! Stay safe!
Thanks again!
Fred
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1992 Mariner 200 Tac circuit question! fatfred69 Mercury & Mariner Outboards 0 May 4th, 2008 10:52 PM
1992 Mariner 200 Tac circuit question! fatfred69 Mercury & Mariner Outboards 0 May 4th, 2008 10:51 PM
1992 200 HP EVINRUDE POWER LOSS RSTOLER Johnson & Evinrude Outboards 0 September 20th, 2003 06:43 AM
1992 60 HP Evinrude VRO Horn Signal Tracker Matt Johnson & Evinrude Outboards 3 September 8th, 2002 10:36 AM
1992 60 HP Evinrude VRO horn signal Tracker Matt Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 September 6th, 2002 09:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
