  #1
Old May 5th, 2008, 06:54 PM
speedylb speedylb is offline
Default 1977 mercury 850 thunderbolt will not start
hey i just got this engine and boat, trying to figure out how and why this engine will not turn over. i turn the key and it sputters and acts like it wants to start, occasionnaly it will misfire but not turn over. would some help on this issue. thanks
  #2
Old May 5th, 2008, 07:23 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: 1977 mercury 850 thunderbolt will not start
Fist off when you say "won't turn over" any of us with half a wit to-wards mechanics will consider the fact that the engine won't rotate by way of the starter.
Now myself being slightly psychic have visions that perhaps what you are trying to say is.........
That the engine rotates or turns over with the starter, but won't quite catch and run on it's own.
Or maybe it won't even start to catch, but might give some indication that it wants to run but just doesn't.
Perhaps you try using the choke while turning it over with the starter.
  #3
Old May 5th, 2008, 07:31 PM
yes the engine turns over but wont catch and start, hope that makes more sense. the manual choke doesnt seem to work or the push button one either any other suggestions.
  #4
Old May 5th, 2008, 07:46 PM
the flywheel does turn when i try and crank it over.
  #5
Old May 5th, 2008, 08:17 PM
jimg984 jimg984 is offline
could try spraying gas/oil mixture into the carb openings
  #6
Old May 5th, 2008, 10:45 PM
jeff_smith_0423 jeff_smith_0423 is offline
Hey speedy. I have your exact same motor but i'm not an expert on it or any outboard by any means. Ask the right questions around here and you'll get all the info you need. If you're going to seriously consider using this motor, you should get a factory repair manual or a Seloc manual if you can't find one.
A few things you should do before seriously running your motor - Go through the "Reviving an old outboard" faq that's posted on this site.
Your motor is a two stroke, and it depends on three things to actually fire and run. Compression, Spark, and Fuel. If all three are there, it will run. Will it run well? Maybe not, but it'll at least catch and fire.
Your motor should have a manual choke knob that you can pull up and activate the choke. If your electric choke isn't working, I'd probably suspect that your wiring harness is rotten or you have rotten wiring in your control box. I'm assuming that you did not hear this motor run before you got it - that being said, you really need to start from scratch with the revival process, inspect all of the wiring, check compression, spark, and inspect your fuel pump and carburetors. They will most likely need to be rebuilt and you'll probably need to replace all of your under-cowl fuel lines.
Don't forget to run that motor on a motor flusher or in a test tank - you'll fry your water pump impeller in a hearbeat.
Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1970-1973 mercury 850 thunderbolt dlaruffa Mercury & Mariner Outboards 6 April 29th, 2008 05:47 PM
1976 1500 thunderbolt on boat w/1977 850 fish4fun2 Mercury & Mariner Outboards 2 October 26th, 2004 12:05 AM
Info on a 1975ish Mercury Thunderbolt 850 Zikka Mercury & Mariner Outboards 4 July 1st, 2003 10:23 PM
Mercury 850 thunderbolt rebuild project MercMark Mercury & Mariner Outboards 1 June 12th, 2003 12:11 PM
1976 mercury outboard 850 thunderbolt boatroper Mercury & Mariner Outboards 2 June 25th, 2002 09:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
