  #1
Old May 5th, 2008, 02:13 PM
favre04 favre04 is offline
Default How to check water pump on a 2hp evinrude?
Is there a trick to check if the impeller works? Where is water suppose to get out? Any advice?
  #2
Old May 5th, 2008, 02:30 PM
F_R F_R is online now
Default Re: How to check water pump on a 2hp evinrude?
Well, having worked for the dealer and having also owned a 2 myself, I can tell you that it is very difficult. It is supposed to blow water droplets out the exhaust relief holes in the rear of the midsection. But the truth is it just runs down the inside of the housing and usually doesn't blow out. I threatened to drill a pee hole in mine, but never did. Hint: The flat plate on the side of the cylinder gets sizzeling hot. So does the cylinder head immediately around the spark plug. The rest of the powerhead should remain reasonably cool.
  #3
Old May 5th, 2008, 03:31 PM
BF BF is offline
on mine, it does blow small droplets out those little relief holes. Can be hard to see, but if you hold your hand in front if it, it gets wet. I changed the impeller on mine (eventhough it did seem to pump water), it pumped quite a bit more after. It's such an easy job to change it, you should just do it if you're at all worried about it's condition, or you don't know if/when it's ever been done before.
  #4
Old May 5th, 2008, 06:23 PM
Scaaty's Avatar
Scaaty Scaaty is offline
Yep, stick it in a garbage can, fire it. Should get yer hand wet out the relief holes if the pump good. I have a 71, and worked on a neighbors 72. It wasn't pumping much at all. Have a great old time dealer here in town, and sold me an upgrade kit for it. Cost $45. Has a new housing, SS cup, different impeller...pumps like crazy now. Any good old Johnny/Rude dealer should know of it. Theres a mess of those motors out there.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Evinrude 90 HP , How to check trigger and VRO pump? sledstew Johnson & Evinrude Outboards 2 April 1st, 2008 09:33 PM
how do I check if my water pump is working?? gmanh4u Mercury & Mariner Outboards 3 August 14th, 2004 06:34 PM
how to check evinrude 7.5 hp water pump John Jennings Johnson & Evinrude Outboards 2 December 22nd, 2003 01:38 AM
98 Yamaha / How to check water pump? gwp Yamaha & Suzuki Outboards 0 April 13th, 2003 05:45 AM
OMC 2hp water pump JB Johnson & Evinrude Outboards 2 April 25th, 2001 07:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
