Greetings all,
Here's me situation:
1989 Johnson 110HP J110TLCE. After 24 months of storage, it wouldn't start, cranks, but was stubborn to turn over. So I did the following.
Compression check results: 100 all around.
Replaced all 4 plugs, wires, rebuilt both carbs (pretty easy - used OMC carb kits) disabled the VRO (using pre-mix now), cleaned fuel tank and filled with fresh premix. It started on the dime, fired up quickly as a matter of fact. I did not do the water pump/impeller yet, that?s next. However, even thought it idles forever without stalling on the muffs, it seems to burn very rich, you can smell it notice the blue smoke. Also starts to hesitates and shake as it warms up. Pulled the plugs after 15 minutes, they were a little wet, cleaned, dried them up and back in they went. Started right up, but again hesitates and occasionally sounds like its going to stall, but it doesn?t. I never recalled doing any timing adjustments or carb adjustments (rich/lean) as of today. I remember this hesitation last time I had it out in the water 2 years ago. Totally clueless. It seems that the carbs are burning to rich. My Johnson manual doesn?t clarify. Any thoughts ??
-Joe
-Joe
