chaddemler1980
- Mar 4, 2008
- 69
ok guys i took your advice now i need some input as to what to use and the procedure. so far i guess ineed to sand the entire boat? gel coat is faded and challky. what grit to i start and finish with? do i do do the entire boat including topside and deck "skid resistant"? also i am looking at 3m products... but which is the better procedure...
1. sand, compound using 3m super compound, then compound again using 3m 3000 "remove swirl marks", then apply wax and buff.... which wax type should i use carnuba "marykate product" or regular 3m wax?
2. sand, compound and wax with 3m 2 in one compounding and wax system. will system work well with a heavy oxidized gel coat. it says it is for heavy oxidized boats, just looking to see if anyone has used this or other 2 in 1 products.
also is sanding even neccesary? wet or dry?
