Large diameter ring terminal replacement needed
aw_snap
Does anyone have any ideas where I can find a large ring terminal (online even)? I need to replace the ring terminal that connected to the trailer between a washer and very large bolt for the safety chain (large enough to fit around the bolt holding the safety chains but with an opening for the standard wiring, 12ish gauge, to crimp into it). The bolt diameter is probably 3/4 inch or a bit more. There are no stores nearby that carry them that size. Thanks.
BillP
Re: Large diameter ring terminal replacement needed
You might google ANCOR and see if they make them in that size...but it sounds like a very oddball size. ANCOR is the brand seen in most marine shops. It's tinned copper...marine grade stuff.
bp
Silvertip
Drill a new hole and use the proper size for a 14-12ga wire. Self tapping screw or smaller bolt will do nicely.
