Rookie Boatman
- Mar 15, 2008
- 17
I've found this site to be a HUGE help for a first-time boat owner, but have one question I can't seem to answer from previous posts. I just bought a 15.5' aluminum fishing boat with a 40 hp Johnson Tracker outboard (1989) and electric start. I have one very reliable dual purpose marine battery with 850 mca/180 reserve capacity that I plan on using to run the following:
- bow-mount 50 lb Minn Kota Power Drive
- Bottom Line 4800 depth finder
- live well pump (when necessary)
- bilge pump (rarely -- no leaks)
- running/nav lights for later in the day
I am fairly confident my dual purpose battery will handle the trolling motor/etc load for a day -- I never go out for more than a day without charging at the cabin/home overnight. Am I right, or a little overconfident? Also, what kind of starting battery is necessary to consistently start a 40 hp outboard? Is a marine starting battery necessary, or can I use one made for automobiles? I don't have lot of extra money, but I also want to buy something that won't leave me uncertain about making it back home, or buying a replacement battery after only a year of use...
Thanks for any insights anyone out there may have!
