  #1
Old May 2nd, 2008, 05:36 PM
mbangler mbangler is offline
Default 1976 Mercury 200(20hp) Ignition Problems!
Hi, I am working on a 1976 Mercury 200(20hp) long shaft, I replaced the coils recently, pulled the recoil and only had my right(facing back of motor) spark plug firing, the left spark plug was dead. I pulled out the ignition wires from the coils, re-inserted, pulled recoil, nothing still. What would not allow that side to fire besides maybe a bad coil? Can someone show me a wiring diagram for this motor and the ignition box, I saw the box had some wires that are not attached to anything. Any help, Thanks a bunch, spring is coming and I would like to go for a nice boat ride!
  #2
Old May 2nd, 2008, 06:10 PM
Laddies Laddies is offline
Default Re: 1976 Mercury 200(20hp) Ignition Problems!
The switch box is probably bad, but it must have all the wires hooked properly get the number off the box if you need the ign test or wiring diagram
  #3
Old May 2nd, 2008, 10:25 PM
kennyboater kennyboater is offline
listen to laddies, he has really helped me!
on mine, i found that i had bad grounds. took them off cleaned and made sure that i had good connections; put them back and it sparks!
  #4
Old May 3rd, 2008, 11:25 AM
Motor Boater Bill Motor Boater Bill is offline
Do you mean right and left coil? The plugs are top and bottom. I've seen new coils that were bad. Try swapping the coils. If the problem follows the coils, the problem is the coil. If the "bad" coil fires after you swap them, the problem is the switch box or the wire. Laddies is right, all the wires should be connected. If you will post your serial number and the number on the switchbox, we may be of more help. Also, be sure the pigtails on the coils are properly grounded, you may need to sand the paint off of the area where the coil mounts to get a good ground.
  #5
Old May 6th, 2008, 10:19 AM
Thanks for all your advice, I tried all that was mentioned, I still am only getting the right coil to fire the spark plug. The left coil is not firing the coil, I reversed them and the right only fired. I cleaned the grounds, etc. When I say right, that is me working behind the motor. The model # is 7068821, the grey electrical box p/n is 332-4911A2. I have the green/white wire to the right side coil, the solid green to the left coil. I replaced the wires and new plugs and still nothing. Can anyone direct me where to look next as I am spending alot of time and the wife is already talking about going boating. This motor has not run in two years, I also noted that when I hooked up the fuel and pressured the ball, fuel went into the carb but when I was trying to fire the motor, no fuel was present on the spark plugs but was dripping out of the motor. What also is the compression for this motor?
  #6
Old May 6th, 2008, 10:30 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Probably the switchbox at this point. Pricey, but available.
Compression of a healthy 200 would be in the 100-120 range, with no more than a 5% variance between the cylinders.
If you've got motor coming out the motor, you've probably got fuel...
- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #7
Old May 6th, 2008, 12:59 PM
311Hemi 311Hemi is offline
Not to highjack this thread, but quick question somehwat related to this users issue. Since this may be the switchbox that is keeping the one coil from firing at all, could the switchbox occasionally keep a coil from firing?
I have an 1985 Merc 20hp tiller and it runs great at WOT, but at idle it runs good some of the time and then starts missing on one cylinder part of the time. I hear a ticking sounds when it does this like the sounds of a spark, but cannot find any melted cables on the ignition side of things. The only worn cable I found is on side of the on/off switch is worn through.
  #8
Old May 6th, 2008, 01:18 PM
311Hemi,
That ticking you're hearing is probably the coil or plug wire arcing to the block. Run it at night and take a look. The spark's origin should be obvious...
- Scott
__________________
  #9
Old May 6th, 2008, 01:32 PM
I would agree it's probably the switch box but heres the test for the system
  #10
Old May 6th, 2008, 01:42 PM
Thanks guys, I know what to look for tonight! That helps!
  #11
Old June 21st, 2008, 09:03 PM
hbowen hbowen is offline
Quote:
i see the specs you have here for testing the stator & dva. my question is // does the engine have to be pulled to get this reading???????? im using an ohm meter but not sure im testing right this engine has set up for two years , it ran fine when stored but now it has no fire . i has replaced the switch box so i guess i need stator and coils. if any one has them i would like to buy. serial # is 4292599 any help is appreciated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1976 20HP Mercury not turning over eeverette Mercury & Mariner Outboards 5 March 8th, 2008 08:15 PM
HELP!! Mercury 200 Ignition Problems extreme76 Mercury & Mariner Outboards 2 September 24th, 2007 12:53 PM
'69 Merc 200 20hp-idle problems Drindin Mercury & Mariner Outboards 6 August 6th, 2007 05:34 PM
'77 Merc 20hp Ignition Problems (fires one cylinder) mtskinne Mercury & Mariner Outboards 3 May 25th, 2004 12:20 AM
1978 Merc 200 20hp problems Olde Merc Mercury & Mariner Outboards 2 June 16th, 2003 05:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
