  #1
Old May 1st, 2008, 10:22 PM
gentner8 gentner8 is offline
Default New boat owner, stuck 3.0 4 cyl
Hello, Im new to the board and boats for that matter and this is my first post. I just picked up a 1994 bayliner with a 3.0L mercruiser I/O. The boat sat for about 3-4 years, and unfortunately did not get properly winterized. The previous owner did remove the plug to let the water drain from the manifold. I put a new battery in and all I get is a click from the starter. I disconnected the alternator belt, and found the alternator to be frozen. I pulled each plug and sprayed a bunch of WD-40 and seafoam deepcreep into each cylinder.
Thats where I stand as of now. The motor looks very clean from the outside with no visible cracks. I am wondering how I can manually turn the motor over to get it broken loose. The owner said it ran smooth as silk when it was last run, and led me to believe there were no problems. Before I go choke this guy out and go to jail, can somebody offer me some help on how to get this motor to rotate? I assumed I would have some work to do, but a locked up motor does not sit well with me. PLEASE HELP IF YOU CAN!!!
~Jay
  #2
Old May 1st, 2008, 10:43 PM
bhammer's Avatar
bhammer bhammer is offline
Master Chief Petty Officer
Default Re: New boat owner, stuck 3.0 4 cyl
Welcome to iBoats. Lots of good folks running around here with lots more info than me. If you just want to turn the engine over, there is a bolt on the front of the harmonic balancer. Maybe 7/8" socket with a ratchet. Turn it clockwise with the plugs out. Then, we can go from there with any other work / issues.
__________________
2007 Starcraft Limited 1900 RE
Mercruiser 4.3L MPI w/ Aplha
  #3
Old May 2nd, 2008, 07:26 AM
I dont remember seeing any bolt on the balancer, it felt more like a hole in the middle. It is obstructed by the front motor mount though. I will check into it a bit deeper today since my temper got the best of me last night.
  #4
Old May 2nd, 2008, 08:30 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Ayuh,.......
Pull the Drive 1st,... Then you'll know whether it's the Motor or the Drive....
Then pull the Starter,+ Bench Test it......
While the Starter is out,... You Might be able to turn the motor with a bar against the Ring Gear.....
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #5
Old May 2nd, 2008, 10:44 AM
Dakota47 Dakota47 is offline
sell it.
  #6
Old May 2nd, 2008, 10:56 AM
Silvertip Silvertip is offline
If the motor is currently seized and you are successful in unsticking it, you may as well remove it and rebuild it. It won't run long even if you do get it running.
  #7
Old May 2nd, 2008, 11:19 AM
Lakester's Avatar
Lakester Lakester is offline
Quote:
hello,
i have seen stuck automotive engines, same as your's just a 6 and in a truck come back to life with careful unsticking procedures. took a while, but in the hands of a good mechanic it can be done. the engine ran for another 25,000 miles. u sound as if u have engine experience.
how long has it sat with the oils in cyls? if it was mine i would consider a plug hole adapter and put some compressed air into each cyl. will help to move oils around. i would use at least 100 psi.
then i would pull starter and use a BIG screwdriver or something suitable to leverage in between ring gear and housing. i would then start to apply pressure in the hopes of getting some rotation. i would be content to apply pressure many times, even if it did not want to rotate at first. i would not force it, but i would be determined.
generally, a stuck engine that has to come apart can be serviced well with a complete cleaning of individual parts and some fresh gaskets. etc. also if u do that, i would have a valve job done also. just use standard engine disassembly procedures and same to buttom it back up...
regards
lakester
__________________
Lakester Special
'71 85HP Evinrude
  #8
Old May 2nd, 2008, 10:03 PM
I pulled the starter and found it was locked. The gear would snap in and out, but would not rotate. I replaced it and drained and refilled the gas and it fired right up. It didn't even tap a bit when it started.
Now I need to figure out why the trim is not working properly. It took a few seconds for it to do anything, then it finally started to lower. When I tried to raise it it only move up a little bit then stopped. I can hear it whining, almost like there is air in the line or something. Any suggestions?
I very much appreciate the help thus far in my quest.
  #9
Old May 2nd, 2008, 10:14 PM
Bond-o's Avatar
Master Shipwright
Ayuh,........ Fill the Oil Reservoir...... I use ATF......
__________________
  #10
Old May 2nd, 2008, 10:19 PM
Coors Coors is offline
~Jay
There is on-line factory manuals here, that you need to read.
Use search.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
new boat owner spacerust Boat Topics and Questions (not engine topics) 6 February 22nd, 2008 12:54 AM
New boat owner rcruz31 Yamaha & Suzuki Outboards 10 January 31st, 2008 09:54 PM
Need Input on New Boat Purchase... (First Time Boat Owner) TheChad Boat Topics and Questions (not engine topics) 10 June 2nd, 2005 05:22 PM
new boat owner oil looks milky boat runs but almost dead? Is this a sign the mot charriex2 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 August 2nd, 2004 06:13 PM
new boat owner no clue of age of boat & motor GREGH Johnson & Evinrude Outboards 15 September 8th, 2001 05:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
