Mercury 4.5 hp need help putting on lower unit
gustafsonerik
Hi i have a 88 mercury 4.5 hp i just changed my water pump and i'm having a hell of a time putting it back on(not lining it up with the shaft,etc) any pointers??? thanks Erik
Windykid
Re: Mercury 4.5 hp need help putting on lower unit
If you left it in nuetral, you will have to turn the flywheel to line up the splines, also check the water tube alignment.
