  #1
Old May 1st, 2008, 09:08 AM
jcunningham jcunningham is offline
Default Fuel Leaking From Carb. 235hp Evinrude
I've got fuel leaking from the bottom carb of my 235 Evinrude. Even when the engine is off and I pump the bulb or when I turn the key and the fuel pump comes on it pours out the bottom carb. Any ideas on how to fix this?
  #2
Old May 1st, 2008, 09:22 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Fuel Leaking From Carb. 235hp Evinrude
adjust the float http://forums.iboats.com/showthread.php?t=244013
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old May 1st, 2008, 04:30 PM
Thanks Tashasdaddy,
Do you think that will fix it's running problems? It was running good for about an hour into the waves and wind, but when we turned down wind it slowed to about half power. I got it into a bay where I could get it to go full out for 20 sec. and then it would die down again. Now today it seams like it won't even go.
  #4
Old May 1st, 2008, 06:00 PM
Hoss 350 Hoss 350 is offline
Quote:
Originally Posted by jcunningham View Post
Thanks Tashasdaddy,
The float might just be stuck. This happened with my Johnson 130. It comes out of the overflow hole, fills up your cowling with gas... Not a good thing.
I freed mine up with a little cleaning and a touch of 2-stroke lube. No leaky.
And yes, this would cause whatever hole or holes this carb is feeding to flood out big time, meaning that only the cylinders fed from another carb would be running right. This could definitely cause it to run poorly.
As an aside, i struggled to figure out how to pull the float bowl for about 20 minutes before I realized it won't come of without pulling the carb. It is really quite easy to pull the whole thing off, takes less than 5 minutes. This is on my motor, though, never worked on a big 'rude...
  #5
Old May 2nd, 2008, 12:34 PM
Thanks Guys,
This is my first boat, so I called the mechanic. I'll let you know how it works.
THinks are a little primative here in the Bahamas, so it could take time to get parts.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
fuel leaking from carb ovidiu Yamaha & Suzuki Outboards 5 April 10th, 2008 09:51 AM
Fuel leaking from carb ZmOz Mercury & Mariner Outboards 3 July 23rd, 2005 05:05 PM
Carb leaking fuel z851 Mercury & Mariner Outboards 2 July 6th, 2004 06:22 AM
carb leaking fuel..... bw6653 Non-Repair Outboard Discussions 5 May 18th, 2003 10:33 AM
carb. leaking fuel from jet when primed. Help!! Carb. specialist needed!!! tundrarules Mercury & Mariner Outboards 6 May 15th, 2002 02:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
