  #1
Old April 30th, 2008, 12:20 PM
msoffee msoffee is offline
Default 1965 6hp Evinrude Fisherman Water Pump
I have a 1965 6hp Evinrude fisherman that has been overheating on me. It is not pumping water out of the exaust hole on the lower drive. I was able to get a water pump repair kit, which has the impeller and a cover plate, but I'm not sure how to get at them to replace it. Does this sound like a water pump problem, and how do I get at the water pump without taking the whole drive unit apart?
  #2
Old April 30th, 2008, 01:05 PM
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
Default Re: 1965 6hp Evinrude Fisherman Water Pump
It's a little different than my 5hp Johnson but you need to drop the lower end and take the pump off from there. The gear case can remain intact. The water pump will be exposed on top of the gear case with the drive shaft sticking out of the center.
  #3
Old April 30th, 2008, 01:46 PM
F_R F_R is offline
Not sure about the 1965, but that was about the time they changed the shift rod disconnect. Eariler ones, you have to remove the powerhead to disconnect it. After the change, you drop the lower unit down about 3/4" and remove the bolt from the brass connector you will see inside. It's one or the other, so drop the lower and see if there is a connector. If not, off comes the powerhead.
Hint, on the newer type, remove the spark plugs and slowly turn the flywheel as you drop the lower unit. A pin in the drive shaft has to align with a slot before it will come down. Don't force it and break it.
  #4
Old April 30th, 2008, 02:24 PM
Thanks Evinrude Boater. I will take it apart tonight and see what it looks like. Thank you also for the pic.
  #5
Old April 30th, 2008, 02:26 PM
Thanks FR. I hope it is the newer type. I will check it out tonight.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
water pump on 1971 6hp evinrude rkaib Johnson & Evinrude Outboards 10 November 22nd, 2008 10:55 PM
Water pump 1987 6hp Evinrude sailorgeo21 Johnson & Evinrude Outboards 6 November 13th, 2008 12:50 AM
manual for 1965 evinrude 6 horse fisherman? tashasdaddy Johnson & Evinrude Outboards 3 July 1st, 2006 07:04 PM
dial on 1965 evinrude fisherman OBJ Johnson & Evinrude Outboards 0 July 1st, 2006 01:41 PM
Water pump for a '74 6hp fisherman Graeme Cushnie Johnson & Evinrude Outboards 3 May 28th, 2004 09:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
