Tachometer Poles 1978 140HP Evinrude
sammons
I bought a tachometer for this motor does anyone know how many poles this needs to be set on to make it work?
HighTrim
Re: Tachometer Poles 1978 140HP Evinrude
6p, this may help. Tachometers read off the alternating pulses from the stator. Tachs have rotary switches on the back that set it to different numbers of coils in the charging circuit, times two because there is a positive and negative pulse for each coil for each cycle. Tachs measure pulses.
http://ww2.tflx.com/pdf/obtach~1.pdf
http://ww2.tflx.com/PDF/99320.pdf
Wow, 3 at once.
