nolaphoto1
- Mar 15, 2008
- 2
Hello everyone. I am new here. I was hoping I could get some advice here. I just bought my friend's boat since he just bought a new carolina skiff. It's a little 15' welded jon with a 1988 15 hp evinrude, model E15RCCS. The only issue I see with this motor so far is that the impeller is in need of replacing. Under power it has a weak stream of water ejecting from the back. It flows fine under forced pressure from the muffs with a hose. SO I am confident there is no restriction and therefore the issue is the impeller. I have ordered the complete water pump rebuild kit. Can anyone offer advice? What has me most concerned is that I can't seem to find anything regarding a seal or gasket that to me SHOULD be between the lower unit and the mid section. I don't see one on the evinrude parts list or drawings. Is there one? I would think there would be one between these two portions of the outter casing. I see on the drawings where the 6 bolts go (which I also ordered new ones) and I see where they attach but I don't see anything where the lower unit slides into the mid section. Am I missing something here? I haven't performed any disassembly yet so I am basing this completely on the evinrude drawings.
