Hi everyone, I have a Force 120HP, early 90s model. Came with the Maxum line of boats. I don't have the serial #, but it's the black cowling cover, early 90s series. I'm sure you know.
Anyways, I'm having a problem with the starting of it. It will turn over and turn over and turn over, but will not fire and stay on. It will turn over like I said, do a quick sputter and then die. After a few of the sputters, it will continue to turn over when I try it, but nothing, until eventually I can hear the battery being drained and give up.
I have tried numerous things so far, but nothing has fixed the issue. Things I have done;
- new starter as of last summer (cleaned out the bushings, etc)
- new battery, fully charged, cleaned the poles, connections, filed them, etc
One thing I have been trying are different methods for starting it;
- not using the choke, and just turning the key
- choking (pushing in the key while turning it over), I can see the choke engaging so I know that's working
- playing with the throttle while attempting to start it, with the choke engaged, and without, but still nothing
- I have also tried having someone engage the choke manually while turning it over, and nothing, also tried priming the bulb while turning it over, and still nothing. I figured this would do it, and I can hear fuel being pumped into the engine, but for some reason I'm not getting it to fire
I was told by my mechanic that I should prime the bulb nice and tight, engage the choke and just turn it over until it finally fires. I have tried this and nothing. I don't want to keep doing it because I will burn out the starter and anything else involved with starting the engine.
Last year I adjusted the idle setting to bring up the rpms at idle speed. Do you think that may have had anything to do with the starting problem?
I haven't swapped out the spark plugs yet this year, but I will. I don't think this is the problem though. But I could be wrong.
What other things should I consider? Fuel pump, impeller, anything else?
Thanks in advance everyone, hopefully get this figured out soon!
EDIT: I've attached some pictures, just to clarify make and model.
Scott
Scott
