  #1
Old April 28th, 2008, 12:40 PM
jdupree jdupree is offline
Default Fuel delivery problem 200HP Mercury
I have a 1992 Mercury 200HP Offshore. You can start it up cold and it will run all day long at whatever speed you desire. Once it is warm and you cut it off for 10-15 minutes when you try and re-start it will run for about 15 sec and then cut off. At this point the primer bulb is "limp". I have noticed that when it starts to die I can pump the bulb and it will "perk" back up and continue to run. It seems like once you cut the motor off and let it sit that the primer bulb will go limp and loose the gas that is in there.
My first thought was pickup tube but I replaced my tank last year and installed new pickup, hoses, and primer bulb. Could these be the symptoms of a fuel pump?
Any thoughts or experiences with similar problems would be appreciated.
  #2
Old April 28th, 2008, 02:14 PM
j_martin j_martin is offline
Default Re: Fuel delivery problem 200HP Mercury
I'm assuming it's a carb motor. The fuel pump could be on it's last leg. It's about a 25 buck kit and an hour to throw it in, unless you know what you're doing, then it's about ten minutes.
It's normal for the bulb to go soft, as you are sucking fuel through it. It should not collapse, as that indicates excessive vacuum in the fuel line.
I would throw in a fuel pump kit and try it. If you are still having trouble, put a piece of clear line (temporarily) between the primer bulb and the engine, and observe it when you're having trouble. Any bubbles indicate an air leak.
hope it helps
John
  #3
Old April 28th, 2008, 02:18 PM
A second thought.
If you can pump the bulb, and it continues to run and keep running normally without further ado,
It could be a combination of bad check valve in the primer bulb, and a small leak anywhere from the primer bulb to the carbs allowing the fuel to fall back down the fuel supply tube after shutdown.
hope it helps
John
  #4
Old April 28th, 2008, 03:27 PM
Thanks for the tips j martin. I was planning to go ahead with the fuel pump kit. Might go ahead and replace the primer bulb while I am at it.
  #5
Old April 28th, 2008, 03:29 PM
Be sure it's a mercury bulb and hose kit. The aftermarket stuff isn't up to delivering the kind of fuel flow that engine needs.
been there, done that.
John
  #6
Old April 28th, 2008, 05:07 PM
John
As a matter of fact, the primer bulb is a Moeller from Boater's World. That could be a problem???? Come to think of it, this problem might have started when I replaced the primer bulb when I replaced the tank. Thanks!
  #7
Old April 28th, 2008, 05:55 PM
BINGO!!!
Throw in the pump kit anyway.
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 200HP EFI Fuel Pump Problem daguvna Mercury & Mariner Outboards 4 March 28th, 2007 12:02 PM
Fuel delivery problem clough Johnson & Evinrude Outboards 14 September 14th, 2004 05:32 PM
fuel delivery problem? sadam68 Johnson & Evinrude Outboards 2 July 20th, 2004 07:48 PM
fuel delivery problem grizzlybars Johnson & Evinrude Outboards 0 July 9th, 2003 07:36 AM
fuel delivery problem cschauerj Non-Repair Outboard Discussions 10 November 25th, 2001 04:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
