  #1
Old April 28th, 2008, 11:37 AM
jd438 jd438 is offline
Default 1989 70hp Mercury ignition
I bought a '89 Mercury 70hp engine that has been sitting for 2 years. When I got it hooked up the engine will crank, but I have no spark on any of the cylinders. Then I started looking around and have a few extra wires that look like they would go to a warning horn and maybe a tilt/trim gauge. One was a purple wire that had a pigtail on it and said(ign.) I have a feeling that I may just have a switch problem that is not turning the ignition on when I turn on the key. Also I have the oil resivior disconnected, that wouldn't have anything to do with it, would it? I have looked through my book and I am confused on where to start checking. Any suggestions?? What wires should have voltage, or should I be checking ohms?
Any help
  #2
Old April 28th, 2008, 12:07 PM
Laddies Laddies is offline
Default Re: 1989 70hp Mercury ignition
Disconnect the black yellow wire from the switch box and check for spark if you don't have spark then you will have to test the ign. system. Don't on any reason hook any voltage to the system it will burn something out!
  #3
Old April 28th, 2008, 03:45 PM
I show two black and yellow wires going to the switch box, one from the controls and one from the mercury switch and they may be on the same terminal. Should I disconnect both?
  #4
Old April 28th, 2008, 08:22 PM
Ok, I diconnected the black and yellow wire, and I have spark. What should I do next?
  #5
Old April 28th, 2008, 08:31 PM
If you did both, then hook the key back up and check for spark to see if the problem is in the control wiring or the mercury switch.
  #6
Old April 28th, 2008, 08:51 PM
They actually have both on one terminal. They don't seperate.
  #7
Old April 28th, 2008, 09:05 PM
I got them seperated. Had spark when the controls were attached. Thought for fun I would try hooking up the mercury switch and had spark after that too. not sure if it shook something loose somewhere or what. Still might look at replacing that switch I don't want to be out on the water and something to not work. I need to replace some fuel lines and try to fire it up tomorrow.
Thanks for the help.
  #8
Old April 28th, 2008, 09:20 PM
gogono2 gogono2 is offline
before you go buy a new switch unessarily, you might consider getting a crank test by a pro. The books have the procedure at less than hour of labor at about $65 bucks. It might be worth it since you cant return electrical parts. Or you can always go by a DVA meeter and crash course voltage readings. I had the same intermittant spark issue and it turned out to be a bad stator (which was brand new) and a bad trigger.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Mercury 70HP Ignition Problem kltrev Mercury & Mariner Outboards 0 April 14th, 2006 07:36 PM
1989 Mercury 70hp Reputation NJCoastFlyFish Non-Repair Outboard Discussions 17 September 23rd, 2005 04:50 AM
1989 Mercury 70hp Reputation NJCoastFlyFish Mercury & Mariner Outboards 10 September 21st, 2005 09:36 AM
1989 Mercury 70hp Shifting and Shocking Black Max Mercury & Mariner Outboards 0 June 9th, 2005 10:11 PM
1989 70hp mercury will not start! Rinker Mercury & Mariner Outboards 7 July 24th, 2002 07:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
