I have very little experience with Bennett trim tabs. What limits the extremes (full up and full down) to keep the hpu from running past the endpoints, if the helm switches are engaged too long?
How does the Bennett automatic retractor work? Is it just a timer relay that energizes the retract wiring circuit long enough to raise the trim plates? If so, installing would only amount to getting in series with the "bow up" circuit of each switch, correct? (as opposed to installing anything at the hpu or trim rams).
Thank you,
-Dale-
Thank you,
-Dale-
