1997 Mariner 115hp...lost my reverse
my 97 mariner 115 lost reverse. when you shift it into reverse the gears grind but they won't mesh. You can feel the grind in the shift lever (quicksilver 3000) but also hear it at the engine. Out of the water, when running, reverse works fine. Is the problem in the shifter or in the engine? Any ideas as to what the problem might be? Thanks for any help.
