Bayliner Model # ?
reid
I have recently aquired a 1990 Bayliner Capri, however there is no sign of the model # anywhere. The HID # is BLOC16CRK990. I assume the model would be a Capri 1600, but I wanted to make sure so that I could order some cosmetic parts for the boat. Any help would be much appreciated.
Re: Bayliner Model # ?
Ayuh,.....
I Believe,...
The Model would be Capri,+ then the Length...
So,....
If your's is about 16' long,.. It'll be a 1600 as you state......
Most of the 1s I see mentioned here are the Capri 185s which are about 18' long...
rbaz
Call bayliner and give them the hull number. They'll tell what it is.
877-861-6494
Dave K.
agree w/ bondo. capri is the model then add the size. i've seen them as big as 32' on the lake where i go. boat looks just like mine only on steroids...
