Grits
- Nov 20, 2007
- 154
Hello Everyone!
I am getting closer to painting my '93 120 Evinrude; however, I have run into a couple of stubborn parts. In the images below, you will see the bottom of the midsection of the motor. I cannot find an exploded view of this part of the motor.
It looks like a press fit. In the bottom of the second image you will see a small hole in the center. In the photo, it is angled down. The part is upside down so it would be angled up if it were on the boat. I thought it may be for a pin. If it is, it bottoms out. It does not go through the tube. Is is going to be very difficult if not impossible to support in a press. I wanted to ask a few questions anyway before I started putting a lot of force in it.
There was a nut on the threaded end of the tube that took a lot of persuasion to get off.
I will take any and all suggestions.
Thank you for your help.
Grits
Grits
