suntracker2
- Mar 22, 2008
- 6
I hope someone can help me, I have a 50hp merc I believe it is an 85 model not sure though. The plate says serial # A 101153, I have not been able to find out for sure maybe someone can asist on this also. I just bought it motor turns over great but does not appear to have spark. I have done the following so far pulled 1 & 3 plug no spark seems to have plenty compression all plugs are new NGK's, checked gas and primer system all seems ok. Brand new switch box installed prior to me wasn't the problem. The key ignition seems to be ok, I disconnected all black & yellow wires coming from ignition 1 at a time thiinking a grounded switch nothing. Everthing seems to be doing what it should be doing choke solenoid, starter, battery, I'm thinking it may be ignition trigger but I don't even know what that does. I thought about it being a stator but I'm under the impression thats to keep battery charged? Any ideas I could try I have no idea of the model # only that it is a 50 hp Mercury. I would appreciate any help and suggestions I do plan on buying a shop manual for it once identified model #.
