hello guys new to site and fairly new to outboards i just bought a 1960 boat and it came with a 68 evinrude lark selecshift the guy started the motor with jumper cables from battery to the starter it fired right up ran a little rich but ran when he went to shut it off he pulled the plug wires from the plugs the top wire never changed the engine at all the bottom wire killed the engine why is that??? next i get the boat home following weekend i tried to start engine hooked up the cables went to the starter and the starter only turns the engine over once then just stops i dont know if the battery was week but i tried 3 different batteries same exact problem the starter kicks up hits the flywheel spins it a half turn or a full turn then just stops then the jumper cables start getting hot why is this ??? next the guy said it needed a new control box (new throttle,select buttons,and ignition) found exact one on ebay got home spliced all wires together hooked upo battery and nothing put meter on it getting power to silenoid ground wire tight and clean also getting power to key but it will not spin the motor over there are a few wires that are just lying in the motor dont know where they go plus when i start the motor with the rope the prop spins but it is not hooked up to any wires i thought the older motor goes to nuetral when no power hooked up???
sorry for so many questions but i wanna go fishing please help if you can thanks in advance
