  #1
Old April 27th, 2008, 12:34 PM
pallet king pallet king is offline
Default Yamaha audible alarm and low rpm
I have a Yamaha 200 2-stroke HPDI, I think a 2003, 2200TXRB. I am a rookie.
Yesterday, out on the water, I got an audible alarm and the engine would not allow me to run over 1900 rpm. I assumed I had an overheating alarm and that the engine was going into safe more. I was 10 miles from home and I had my four daughters, nervous wife and labrador in the boat. Everyone looked at me like, "nice going, idiot" and time began to pass a little slowly.
I beached the boat and shut it off for an hour and a half. When I turned the key, alarm returned. I disconnected the sensors on the heads (yellow and brown wires)...alarm remained. Both test open on the fluke continuity sensor. The engine is not hot to the touch. The engine and reserve oil reservoirs are full. The engine reservoir fills when I toggle the switch by the tank.
Assuming I do not have a heating issue, and the engine is receiving oil, I am thinking I have a bad sensor. Other than the head sensors, what else could be setting off the alarm? Are there too many to list? And am I on the right track?
I apologize for this post in advance. Reading pasts posts for this issue, mine seems juvenile and stupid...but I could use some guidance on where to go from here.
  #2
Old April 27th, 2008, 04:49 PM
rodbolt rodbolt is offline
Default Re: Yamaha audible alarm and low rpm
and here is where the yamaha digital multi function stuff shines. if you have the tach and the speedo or speedo fuel management then look at them, they will indicate for overheat,oil in the engine tank oil in the remote tank(no audible on that one) low battery voltage and the kicker, water in the fuel.
the HPDI motors had a water detect sensor in the fuel water filter on the engine on the later models, if yours is equipped it will have wires coming out, there are also various filters sold that have water detect.
if you have the fuel management meter and no water detect if the red/white wire thats unused near the fuel flow sensors gets wet with salt water it will trigger the alarm.
later 05 and up I think, HPDI motors have water detects but the alarm WONT sound if the engine is in gear, only in nuetral, you figgue out why, I quit trying .
  #3
Old April 28th, 2008, 12:07 AM
rodbolt, it was water in the fuel water filter in the engine. I appreciate your help. next time I will try to post a more challenging intellectual puzzle!
One daughter held the flashlight while I removed the filter, showed her the water, dumped the contents and refilled with gas. So, with your help, I have shaken some of Saturday's idiot stigma.
Have a great week.
  #4
Old April 28th, 2008, 08:30 PM
easy on the puzzles
poor brain only gets lucky so often.
but DO NOT run it anymore without changing your hull mounted seperator, its full and now is passing water AND creating excessive fuel suction side vacum.
if you dont have a hull mounted filter, install it NOW.
  #5
Old April 28th, 2008, 08:54 PM
TonyNoriega TonyNoriega is offline
Send a message via AIM to TonyNoriega
Have a great week.
I really should know exactly what filter you guys are talking about in case it happens on my 200hpdi. Are you refering to the vapor separator....the metal unit that's forward on the port side? Or the see-through fuel filter that sternward of the vapor separator? Or is there yet another filter that I'm not aware of? BTW, I change my 10-micron hull mounted fuel/water filter AT LEAST once a year and so far no problems down stream from there.....
Thanks!
__________________
tbonefortysix
  #6
Old April 28th, 2008, 10:48 PM
toni
what ya have to remember is yamaha added the feature, its up to the cheap azZ customer and the dealer that monted it to the hull to insure its done correctly.
to many customers simply wish to pay the least, to many salesmen simply want a comission. I am simply a monkey, at least I do have opposible thumbs.
read my first post and it will solve your yamaha issue, your prehinsle tail issue I cant fix.
all I am is a tech, however I am a very dedicated tech.
sharp sometimes, yep, sarchastic sometimes? yep. but I am very very dedicated to making sure my offshore customers come home each time.
  #7
Old April 28th, 2008, 11:13 PM
Rodbolt, I had to head out of town this week...so I can't address this right away, but I am pretty sure I have no hull mounted separator. It would not be an in-line filter I am assuming.
Thanks for the heads up. I'll get it done before I (we) head out again.
  #8
Old April 29th, 2008, 08:17 AM
myself? it should be against the law top sell a hull without a water seperator, preferably one with an alarm, however its not.
takes an hour or less to install and a good one 10 micron with a 60 gallon per hour flow rate, is about 50 dollars.
however probably half my annual income is water in the fuel.
I dont like it, its entirely preventable, but it is what it is.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Audible alarm problem realmasa Yamaha & Suzuki Outboards 2 August 3rd, 2009 06:51 PM
1996 130hp Johnson no oil alarm at low rpm highlander86 Johnson & Evinrude Outboards 1 July 8th, 2007 08:38 PM
86 25-ESJ Yamaha low rpm/ low power. cheesehead4 Yamaha & Suzuki Outboards 6 June 28th, 2007 08:25 PM
Johnson 200 Oceanrunner, check engine alarm and low rpm Jason Edwards Johnson & Evinrude Outboards 2 September 5th, 2006 12:54 PM
audible alarm? gunslinger_pa Johnson & Evinrude Outboards 1 July 17th, 2005 07:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
