  #1
Old April 26th, 2008, 11:53 PM
gearyg gearyg is offline
Default Yamaha 2002 115hp 4-Stroke - Question At Idle Speed
For the first time, I ran my engine on the muffs (I usually only flush it using the attachment). At start up and idle, it sounds fine, but when I shift it into forward -or- reverse at the idle position, I hear a clunking sound, kind of like there is "play" in the transmission or gears, I can also feel it when I touch the engine. However, once I begin to accelerate, it goes away.
Is it that there is no pressure being applied because it is out of the water? And when I increase the RPM's, it is spinning fast enough to eliminate the play?....hope this is normal...thanks.
  #2
Old April 27th, 2008, 03:02 AM
Yamajoe's Avatar
Yamajoe Yamajoe is offline
Default Re: Yamaha 2002 115hp 4-Stroke - Question At Idle Speed
That is normal, the clunk is louder when you engage the shift slowly; use a deliberate fast motion when you shift into gear.
  #3
Old April 27th, 2008, 12:00 PM
Thanks for the reply Yamajoe. The "clunk" sound is "continuous" while in the idle forward/reverse position (prop spinning)...so it will be clunk clunk clunk clunk etc...until I engage at a higher RPM (so basically it will clunking the entire time it is in that position) . I apologize if I was not clearer in my earlier question, but I understand that it it will clunk when I first engage, but that sound continues, are you saying that this is normal also?...thanks.
  #4
Old April 27th, 2008, 05:24 PM
rodbolt rodbolt is offline
yep, its the propshaft speeding up with inertia remember you only get a powerstroke every 180 of crank rotation so the shaft speeds fluctuate, its worse with a stainless wheel.
if it bothers you remove the prop.
but why shift out of the water ?
  #5
Old April 27th, 2008, 05:31 PM
andymach23 andymach23 is offline
When I bought my F40, the dealer ran it on the hose to check it over. When he engaged gear it made a noise like a rattle from the gearbox. When he connected a F100 on a boat that was in for servicing it made the same noise. This was at idle revs. He sent away for a new lower unit from Yamaha as a precaution. When it was fitted it rattled the same.
I concluded that it must be the way the box is. I asked at Yamaha and posted on here about it but did not get a consensus.
I have 120 hours on the motor now with no problems.
Hope this helps
Andy
  #6
Old April 27th, 2008, 07:52 PM
ok. ill try simple physics once more, on a 4 cylinder 4 stroke yamaha 1 and 4 move up and down together as do 2 and 3. when one is compressing gas before fireing it tends to slow the crankshaft as 4 has an open exuast valve and 2 has an open intake and 3 is almost at the bottom of its power stroke., if the crank slows, the driveshaft slows, heavy prop is under no such slowdown and rotates the clutchdog teeth,splined to the propshaft, slightly ahead of the dog on the mating gear, now, WHHHOOOOOSHHH bang, cylinder one fires, the crank rapidly accelerates, now the drive shaft speed is faster than the now slowing propshaft, whack, the dogs hit again. process repeats when number 3 is on its way up, then 4 then 2 then 1 then 3 then 4 and so on and so on. the flywheel helps but can only be made so heavy .take the prop off and the noise disapears, ya outta hear some of the V76 motors that only run on 5 cylinders idle on the muffs with a 15X19 wheel.
so yes on certain engines, especially 4 strokes as power impulses occur every other time the piston comes up, some rattle in gear out of the water is normal.
if it bothers you you have 2 choices, remove the prop or dont shift when flushing.
as that EFI motor doesnt cut cylinders in nuetral there is no reason to ever shift while flushing.
only HPDI kills 2 cylinders in nuetral.
  #7
Old April 27th, 2008, 07:53 PM
Glad to know that it is normal, it actually makes sense now that I think about it and incorporate Rodbolt's responses. Unlike my old boat, I never had to run my Yamaha out of the water, so the first time that I do, I hear a stange noise and begin to freak out about all the $$$ that I may have to spend.
Thanks everyone for the guidance and this forum has been awesome!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2002 150hp Johnson/ Bombardier Idle speed Problems PLEASE HELP!! Does78 Johnson & Evinrude Outboards 5 June 23rd, 2008 01:48 PM
2002 Yamaha 4-Stroke 115hp Voltage Regulator? gearyg Yamaha & Suzuki Outboards 1 March 25th, 2008 07:21 PM
2002 Yamaha 4-stroke 115hp DMBullock Yamaha & Suzuki Outboards 3 November 9th, 2007 08:20 PM
2002 Yamaha 115hp - # of Poles for new Tach? cigar_stub Yamaha & Suzuki Outboards 2 August 10th, 2007 09:05 AM
4HP Yamaha 2 stroke - no idle or high speed power Ted Herford Yamaha & Suzuki Outboards 3 September 11th, 2003 09:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
