Ahoy, nenegoose.
Welcome to iboats.
Your most likely problem is in the wiring for the starter circuit, nene.
Take all big wires from the battery to the engine block and the solenoid off. Clean the connections thoroughly and check them for internal corrosion. . . a bulge in the insulation or a weak spot.
I am assuming that you have made sure that the battery is fully charged.
Let us know what result you get.
