  #1
Old April 26th, 2008, 03:41 PM
jtcarter's Avatar
jtcarter jtcarter is offline
Default 95 175 evinrude intruder (stalling problem)
I just bought this motor and it has a weird little issuse going on. When i first get to the lake for maybe the first couple of hours i don't have any problems with it. Then after that everytime you trim it down and try to push the hotfoot it stalls. After several attempts you can feather it enough to get it up on plane. After you get going no problem and it doesn't hesitate. But it will do it about everytime after you've run it for awhile.
Took it back to where i bought it and the guy says he couldn't find anything wrong with it, go figure. Something is wrong, it shouldn't be stalling. It also spits and coughs every now and then. Anyone out there have any suggestions,please i'am all ears.
  #2
Old April 26th, 2008, 03:57 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 95 175 evinrude intruder (stalling problem)
Welcome to iboats. The syptoms you are describing are classic "heat soak". Seahorse5 explains it best, and this is what he wrote in a previous post.
"You are describing the classic symptoms of heat soak. When the motor is shut off, the residual engine heat increases under the motor cover to as high as 200°F according to factory tests. The gasoline in the carbs and vapor separator tank "boil" away as the motor sits and heat is transferred from the hot cylinder block to the carburetors and fuel system.
When you restart the motor, it is actually running on the heavy vapor fumes and not on liquid gasoline. As fresh gas is pumped into the motor, the temperatures of the carburetor bodies "flash off" some of the fuel, making more vapors until they cool down with air flow. The engine may idle, but will not develop any power on acceleration.
Squeeze the primer ball before starting and let the motor idle for several minutes before taking off. This allows the venturi effect of the carburetors to cool the float bowls and the intake manifolds to the point where they operate normally. Also the lower temperature gasoline from the fuel tank being pumped into the motor helps to cool things down.
The 60° engines, 90-175 hp, are more prone to heatsoak due to their compact design and the use of plastic manifolds and carburetors. They retain heat longer than the equivalent aluminum parts used in other engine models.
Alcohol and various fuel additives promote heat soak due to their lower boiling point. Winter blend fuels have more volatility to aid in cold weather starting and can also aggravate the problem. With the new 10% alcohol gasolines heat soak problems in all types of motors will increase, especially in hot weather.
You can minimize the problem by making sure your motor is in a good state of tune, using Champion QL78YC plugs gapped to .030", and adjusting the relationship between spark advance and throttle opening (sync & link) to occur at the exact same time, and perhaps richen up the idle screws by an additional 1/2 to 1 turn out. With these suggestions and letting the motor idle for a while after restarting, you should be in good shape."
Let us know what you find.
__________________
Chris
  #3
Old April 26th, 2008, 04:38 PM
jtcarter's Avatar
Thanks. That makes sense,when it was a little cooler this year back in march i didn't have this problem. I also rarely let the motor idle very long before i take off. I'll give this a try and get back to you if thats it. Thanks again.
  #4
Old April 28th, 2008, 06:21 PM
ericfebs ericfebs is offline
Exclamation Re: 95 175 evinrude intruder (stalling problem)
hey! did the fix work? I'm having similar problem, but i've got a 200hp Oceanrunner by Evinrude. I'm also losing pressure in the primer ball and I don't detect a leak anywhere. And what's weird is, once is does get going just fine, no problems! my biggest problems are running at idle after the boat has been running which is making slow trolling very difficult. Is it possible I have a problem with a check valve or a problem in the electronic primer system to the carbs?
Thanks!
  #5
Old April 28th, 2008, 06:39 PM
HighTrim's Avatar
Eric start up a new thread so that no one gets confused. Im sure you will get plenty of help.
__________________
Chris
  #6
Old June 25th, 2008, 04:09 PM
jtcarter's Avatar
Quote:
Thanks!
Sorry it took so long to respond. The answer is no it didn't work. I still have the same problem. If you've fixed yours please let me know how you fixed it.
  #7
Old August 6th, 2008, 08:54 PM
budsbud662 budsbud662 is offline
Im also heat soaked, desprate and looking for a fix i have found a few things that may interst you.
1. eddy sent me an email saying - Yes, mine started with the rectifier going out, replaced it, then later, mine started to cough when the power pack was going out only when the motor was warm, but it was reccomended that since all the other ignition was replaced that a new stator be put on, runs great
2. ive heard people fixing it with deleting the vapor seprator, or replacing it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude Intruder 175 problem javelinguy Johnson & Evinrude Outboards 0 June 25th, 2007 12:05 AM
Evinrude 115 Intruder Smoking/Stalling kmenna Johnson & Evinrude Outboards 4 September 21st, 2005 09:56 AM
'95 evinrude intruder 150hp v-6 loop charged jodyv Johnson & Evinrude Outboards 3 September 12th, 2004 05:40 PM
stator test 175 evinrude intruder toprosa Johnson & Evinrude Outboards 0 August 16th, 2004 12:17 PM
1993 Evinrude 175 hp. Intruder BigR Johnson & Evinrude Outboards 10 September 10th, 2002 03:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
