  #1
Old April 25th, 2008, 06:51 PM
oldtruckface oldtruckface is offline
Default kill circuit wire color jap made 91 mariner 40elto
hello i've worked on a few merc outboards so I know the colors fairly well,
but this 2 cyl 91 mariner 40elto 6e9 japanese sourced electronics made by
mitsubishi or nissan are totally diffrerent.This motor suffered a violent lower unit
seizure due to water in the gear casing,now after new lower end everything
should be good ,but there is no spark at all,so 1st step-eliminate kill circuit,ok
but which is it? there is no blk/ylw wire .
switchbox 6Z05 7wires orange----coil
white------remote controls
black------ground
brown-----stator
wht/red----stator
black------stator
black------coil
it must be the white that goes to the remote controls and comes back as black and is connected to ground? or the black that goes to ground directly out of the switchbox.
I am getting continuity to ground on both when disconnected
i.e. white from remote control to ground continuity
white from switchbox to ground no continuity
black from switchbox to ground continuity
so maybe the problem is in the key or kill or neutral switches,I hope so!
But then wouldn't the starter not work also?
Once I eliminate the kill circuit I guess ill have to test the stator and
ignition module for output
stator wires black
brown
white with red stripe
with no yellow wires,is there no charging circuit ?
trigger wires two greens
oops this is getting long winded now,thank you very much for any help
ie. wiring diagrams,ignition test specs,any advice at all,by the way I have tried to get a manual for this engine but no luck. thank you
  #2
Old April 25th, 2008, 07:50 PM
Laddies Laddies is offline
Default Re: kill circuit wire color jap made 91 mariner 40elto
White
  #3
Old April 27th, 2008, 09:10 PM
Laddie sir ,thank you very much,I disconnected the whiteand braapappapapppap
started up like my wife after her sunday salon rendez vous with my boss's wife ,brapappapaapp.
So I opened up the controller and The white goes straight to the keyswitch , the neutral start microswitch was broken so I jumped the wires with a connector,but that did not eliminate the continuity to ground on the white, so
does that narrow it down to the keyswitch itself?
If so I'll have to bone up on my soldering skills cause I've done one of those before
and it's like playing twister with my wife after her sunday salon rendez vous......braappapapapp!
I'll have to get a new one ,So that's it ,gotta go skin some chinchilla
thanks for your help
I'm sure I'll be back
  #4
Old April 27th, 2008, 09:15 PM
Faztbullet's Avatar
Faztbullet Faztbullet is offline
Check to see if kill switch cord is off...
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
tach connectors/kill switch wire color roastinears Johnson & Evinrude Outboards 4 November 7th, 2007 07:47 PM
30 Hp Jap Mariner 84' Culmination Mercury & Mariner Outboards 0 July 23rd, 2007 01:14 PM
94 Mariner 115 kill circuit problem? COYOTE54 Mercury & Mariner Outboards 7 November 28th, 2006 02:43 AM
Achris/clams/anyone - ID Jap Mariner manual and parts dj_lennard Mercury & Mariner Outboards 2 July 30th, 2006 11:39 AM
Yamaha kill switch Wiring, which color wire? Stevenhj Yamaha & Suzuki Outboards 2 March 10th, 2005 01:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
