krisnowicki
- Jul 11, 2007
- 1,172
So after my last crusader **** the bed. I did a repower. I bought a 305 from a 228 merc package and an alpha out drive. I have everything on and what not. When I had the engine on the stand on a "boat in a box" ( a 9 pin conn to a box with a siwtch and gauges on it) it ran beautifully. When I was putting it in I hit the distributor cap on the way in to the in to the boat and broke on of the terminals off. So i replace it . I check all the wires everything was tight but today I am getting intermittent spark on my spark tester. I have a thunderbolt iv the triangle kind. So i pulled out my tested and wen down the list. I have 12v at the coil 12 on the red/wht wire to the dist. But little or no charge going to the wht/green wire on the other side of the distributor. I took the saftey interrupt switch off to eliminate and still the same problem. So i followed the wht green back to the T-bolt iv and the grey wire coming from the - side of the coil to the t-bolt has plenty of juice but there is little of no coming back out to the green/white wire. When I put my tester on the green/wht it makes the coil click and I can feel the current go from the coil to the distrib in the coil wire. So bad T-bolt ign module is my guess what do you think?
