hi
I have a 1988 Johnson 150HP V6 outboard. Does any one know if we should have a stream of water coming out of the exhaust ports that are just below the engine cover or should just gasses come out of them. At the moment when running at speed we have spits of water and steam coming out. Could this be a problem or is it just a poor fitting exhaust gasket allowing some water to leak into the exhaust chamber. We have a good strong tell tale which only gets luke warm at speed, it has had a new impellar fitted and the thermostats seem to be working fine.
Any help would be much appreciated.
