Does a 1996 175hp ocean runner model J175EXEDB have a pressure relief valve if so where is located?
hydra23 Seaman Apprentice Joined Mar 18, 2008 Messages 42 Mar 19, 2008 #1 Does a 1996 175hp ocean runner model J175EXEDB have a pressure relief valve if so where is located?
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 28,799 Mar 19, 2008 #2 Re: pressure relief valve It should have a poppit valve. Look up the exploded parts diagrams at crowleymarine.com
S seahorse5 Rear Admiral Joined Jan 24, 2002 Messages 4,698 Mar 19, 2008 #3 Re: pressure relief valve hydra23 said: Does a 1996 175hp ocean runner model J175EXEDB have a pressure relief valve if so where is located? Click to expand... The plastic thermostat capsules are also the spring loaded relief valves. Remove the plastic cap, 13/16" hex - same as a sparkplug, and you will see the spring, capsule, and rubber seal.
