Re: HELP hooking up telelfex cables,OMC box
I could by studying the box "in person". You can do the same. As you move the lever from neutral toward either forward or reverse, you will see one of the inner levers move, then stop and then the other one moves as you throttle up.
The one that moves first, then stops, is the shifter.
Again, study it and use common sense, keeping in mind what has to be accomplished and the direction that it needs to move the controls on the motor and you can figure it out.
