  #1
Old April 22nd, 2008, 08:21 PM
grantusw grantusw is offline
Angry 1981 50 hp mercury fuel problems
I have a 1981 50 hp 4 cylinder mercury and i am having an issue with the fuel getting to the motor. I changed all of the fuel lines, gaskets in carbs, primer, valve at the motor and gas tank and it still is runnig rough. It will lose a little power and if ou pump the primer it will boost the power back up. I have tried everything. thanks for any help you can offer.
  #2
Old April 22nd, 2008, 09:28 PM
mercerfisherman mercerfisherman is offline
Default Re: 1981 50 hp mercury fuel problems
I've got an 84 merc that had the same problem... changing the fuel pump might be your next step in troubleshooting the problem. It sounds like you've addressed the other issues that could affect it. Good luck. If you don't get any more advice... post your problem again... maybe more people will pitch in with some other good advice. Good luck.
  #3
Old April 22nd, 2008, 11:45 PM
lil_jason17 lil_jason17 is offline
  #4
Old May 29th, 2008, 01:01 PM
mcgl403 mcgl403 is offline
Did you ever get this fixed? I have the same problem with the same motor. I have change all fuel lines rebuilt the carbs, and recently installed a fuel pump in line before the primer bulb just to get me in the water. the fuel pump is out of an old Subaru wagon. It runs good but I would like to have it back to norm.
  #5
Old May 29th, 2008, 01:48 PM
TheRealSangster TheRealSangster is offline
How ironic, I just bought a boat with a 1981 Mercury 50 hp 4 cyl that had the same issue from a guy named Grant. Hmm.....
The problem was...........................carb to motor gasket was on upside down, which blocked a fuel port that allowed fuel to flow to the fuel pump.
Runs like a top now.
  #6
Old July 16th, 2008, 01:43 PM
theoz60 theoz60 is offline
I have the same motor, same year, lot of the same problems.
Tried the same fixes. Mine would be running great full throttle
then spit, sputter, idle down & run at idle even though I was still at full throttle. Been trying to get it running good for two summers. 7 times my
"mechanic" said he had it fixed, 6 times I brought it back to him. Not 7!!
Any ideas...ted
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp mercury thunderbolt shifter problems troubledinottawa Boat Topics and Questions (not engine topics) 4 September 13th, 2008 01:07 PM
1981 50 HP Mercury bogs when warmed up breeder44 Mercury & Mariner Outboards 7 October 6th, 2007 02:09 AM
mercury thunderbolt 50 hp running problems paul bishop Mercury & Mariner Outboards 0 May 27th, 2003 02:50 AM
50 HP Mercury Idle Problems sfryz Mercury & Mariner Outboards 1 July 15th, 2002 02:45 PM
Carburetor Problems on a 50 hp Mercury (1982) kbaker7544 Mercury & Mariner Outboards 1 June 24th, 2002 03:19 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
