I have a 1992 Mariner 200 with low hours. It really runs superb, but recently I have been getting an overheat alarm. It has good water pump pressure and the pee stream is strong. I put an IR gun on the heads, and the top two cylinders on both sides are running hotter than the lower cylinders, the left side more so than the right. It has new thermostats, no change. compression is good on all cylinders.
Since the engine sits for long periods, I feel there must be some internal corrosion built up that is impeding the water flow. I would rather not have to disassemble the engine if I can avoid it.
My thought was to remove the thermostats and housings and pour several gallons of either a dilute acid or a dilute alkali into the engine to try and dissolve the deposits, then after a suitable time reassemble the engine and run it to flush out any remnants.
Does this sound reasonable? To anyone? If so, what substance should I use and what percentage strength?
Thanks.
Thanks.
