  #1
Old April 22nd, 2008, 03:48 PM
EDDYSTONE EEL EDDYSTONE EEL is offline
Angry 1996 Mariner 4hp FAULT - stops and wont re-start - Please help
Niggling fault please can someone help fing diagnose and suggest a repair
I start the engine it runs perfect both at idle and high revs in all gears but then after about 10mins it dies instantly just like pressing the stop button it pumps water very well
does not seem to overheat no other problems exept this one changed the coil had new plugs changed the petrol and oil
does not splutter it just dies instantly I have cleaned the carb once it has died it won't start for a long while 1hour plus, If you eave it for a few hours it starts first pull then repeats the same process as above.
Can anybody suggest the next things to check. I was thinking maybe a faulty thermostat (if it has one), not an expert but know way around it if advice is given
THANKS SO MUCH
Hope to be back on water with it soon, wont take boat out without the aux you see
  #2
Old April 23rd, 2008, 10:18 AM
James R James R is offline
Master Chief Petty Officer
Cool Re: 1996 Mariner 4hp FAULT - stops and wont re-start - Please help
Be sure you have the correct plugs. 2 stroke motors can be funny that way.
  #3
Old April 23rd, 2008, 04:40 PM
Default Re: 1996 Mariner 4hp FAULT - stops and wont re-start - Please help
Hi
Thanks for the advice
the plugs are the correct ones and brand new so I rule that out
any other ideas welcome please
THANK YOU
  #4
Old April 29th, 2008, 04:34 AM
Hi
Still no luck with getting it running right
any advice please
thank you
  #5
Old May 15th, 2008, 09:32 AM
Hi
Still not had it running right
can somebody try to help me out please
thank you
  #6
Old May 15th, 2008, 01:25 PM
DRIFTER_016's Avatar
DRIFTER_016 DRIFTER_016 is offline
Sounds like a poor electrical connection.
Check that all your connections are clean and tight.
I had a similar issue with an '89 Honda dirt bike. It would run fine and then just shut off and not restart until it cooled down. I had it in the shop 3 times before they finally got it to cut out. It was a dirty connection (one of the bullet type connectors) They cleaned it with some 0000 steel wool and the problem never came back.
Intermittant electrical problems can be a pia.
It could be a problem with the shutoff switch wiring as well.
If it is a tiller model check where the wiring runs out of the tiller into the powerhead area as the wiring can rub and crack there.
This should give you a start.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 4hp wont start, fuel problem allymoss Mercury & Mariner Outboards 17 February 13th, 2007 02:42 PM
4hp Johnson wont start, possibly coil Ro22Ro22 Johnson & Evinrude Outboards 4 June 28th, 2006 01:22 PM
Cobra Runs Well, but eventually stops and wont start wills-ggl Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 January 5th, 2006 10:00 PM
4hp evin. wont start, pops when trying to start nigel13 Johnson & Evinrude Outboards 4 February 20th, 2004 04:20 PM
Mariner 1996 wont start but does click meusel Mercury & Mariner Outboards 5 June 18th, 2003 02:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
