OMC noise
APfaff
I have an OMC Cobra 190 and when it runs (in gear or out) there is a pronounced noise that actually sounds like it's coming from under the boat. When I turn one direction or the other to full throw it gets stronger. It has gotten progressively worse in the last two or three times on the water. I'm believing it's U-Joint. Any ideas?
HT32BSX115
Re: OMC noise
You absolutely need to pull the drive....next!
You either have a U-joint going bad and/or the gimbal bearing is going bad. You should probably plan on a complete transom "kit".... bellows, U-joints, gimbal bearing etc...if it looks like theres water intrusion or hasn't been replaced in several years...
If your U-joints break it will break other expensive "stuff"!
Cheers,
Rick
I guess I can say this too!.........Welcome to iBoats!
Gary H NC
Re: OMC noise
Agree,The drive needs to be pulled and inspected ASAP....
I would not run it until you check it over.
