Re: 79 evinrude 35hp loss of power while in gear
Welcome to iboats Matthew.
It is likely that you are dropping a cylinder while under way.
Start by checking spark and compression. The compression should be about 100 psi, but more important, even on both cylinders. The spark should jump the gap on an inline tester a good 1/4 of an inch with a bright blue ZAP!! If these check out you will need to look into fuel delivery.
Let us know what you find.
__________________
Chris
