Re: 90 sport jet mercury/force starting
The rev limiter could still be bad. I've had them last less than a year. Disconnect the yellow with black stripe wire, and try again. The auto enrichment on a 95 motor is a wax pellet and a heating element. When the wax melts, the enrichment needle closes. Make sure the auto enrichment has power. Finally, make sure your carbs are clean and your gas is fresh.
good luck
fp
