  #1
Old April 20th, 2008, 10:09 PM
eterry eterry is offline
Default Steering cable for 65 hp Evinrude
I am not sure if this is the right forum, but if not it will be moved. A co-worker is looking at a boat with a 65 hp evinrude. The owner says it needs a tune up and the steering cable is broke. How much time/trouble/money is involved in replacing a steering cable on that size motor? Is there any maintenance that I should be doing to my steering cable? It looks old but it works.
Thanks
Eterry
  #2
Old April 20th, 2008, 11:48 PM
F_R F_R is offline
Default Re: Steering cable for 65 hp Evinrude
Depends on whether you can get it out of the tilt tube without removing the motor from the boat. Also depends on how deeply it is buried in the boat and how much stuff the installer bundled to it. Can be fairly easy, or can be fairly difficult.
  #3
Old April 22nd, 2008, 03:40 AM
Thanks FR, will pass on the info. Is there anything I can do for my cable, maintenance wise ? Just dont wanna have to replace mine any sooner that needed.
Eterry
  #4
Old April 22nd, 2008, 04:33 AM
ksubigbuck ksubigbuck is offline
Quote:
Eterry
Greasing it sure wouldn't hurt! I think they usually get stuck after sitting without use for long periods of time. It might be a good idea to crank your steering wheel full port and full starboard every once in a while when you are out in the garage.
  #5
Old April 22nd, 2008, 08:28 AM
F_R F_R is offline
Regular preventative maintenance demands that the cable be kept lubricated where it slides in and out of the tilt tube. Ignore it and the tube rusts inside and locks up the cable. Then you REALLY have trouble.
  #6
Old April 22nd, 2008, 03:17 PM
Thanks for the tip guys, will try both and see how long i can make the cable last.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Engine or cable issue?? 1972-74 Super 65 Evinrude OB lwcrew Johnson & Evinrude Outboards 4 December 14th, 2006 08:45 PM
Evinrude steering cable remove and replace richsbca Johnson & Evinrude Outboards 1 June 22nd, 2005 11:37 AM
Steering cable Evinrude 60 hp 1980 MadeCoolCom Johnson & Evinrude Outboards 4 May 13th, 2005 09:02 PM
Evinrude 60 hp 1980 replace the steering cable MadeCoolCom Johnson & Evinrude Outboards 1 May 13th, 2005 08:46 PM
Steering Cable for 65 HP, 1973 Johnson lesterdp Johnson & Evinrude Outboards 3 August 8th, 2003 12:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
