  #1
Old April 20th, 2008, 09:20 PM
JAL51974 JAL51974 is offline
Default Engine cover needs insulation/soundproofing
The engine cover on this 1985 era Capri 1950 has lost all its sound proofing/inside insulation over the years. I know I read some threads about people installing a substitute material. Anybody completed that project and how good is the material? Thanks.
__________________
"SeaDog"
1985 Bayliner Capri 1950 BR
AQ125a/270
Even a bad day on the water is better than a day at work!
  #2
Old April 24th, 2008, 02:07 AM
azlakes's Avatar
azlakes azlakes is offline
Default Re: Engine cover needs insulation/soundproofing
hi Jal,
... good question. i have been thinking this over also when i redo my cowling. the original black insulation is brittle and messy. things i thought to use.
1) foam that you find in shipping thats somewhat egg crate in shape but thicker and more dense. used primarily to protect expensive electronics. p/c's, etc. dont know the longevity however.
2) the black insulated matting you can find under older car hoods. its still available online and comes in pieces big enough to finish the inside of a cowling.
How to mount? I thought either glue the material directly to inside of cowling or j/b weld several thin ss bolts spaced evenly to the inside of cowling and impale the material through and hold with large washer and wax thread nut.
__________________
86' Capri 1950 BR
Force 125hp
Desert Southwest
  #3
Old April 24th, 2008, 04:31 PM
there is a sound deadening/insulation/heat reflective material that has aluminum on both sides and foam inbetween and can be found on ebay..."3in1 product" name but not sure who makes it. Guys on another forum used it and sprayed 3M hi temp glue to stick it on. The company on ebay that sells it is Cowboy AutoParts. If I can find the company that makes it I am going to try to find some locally. If not ebay isn't a bad price, and the roll has plenty for our purpose. If you find out who makes it let me know.
Joe
__________________
"SeaDog"
AQ125a/270
  #4
Old April 25th, 2008, 09:01 PM
Mark42's Avatar
Mark42 Mark42 is offline
There is also the sound deadener used by the BOOM BOOM stereo car guys. Its used to stop the vibration of the body panels. Its thick rubber with a self stick side. It should take the heat of the engine compartment. Do a search for auto stereo suppliers and look at the sound deadener products.
__________________
1985 Bayliner 1600 Capri Cuddy, 1965 MFG Niagara Custom. >> MFG Video<<. >> MFG Project<< >>Bayliner Hard Top Project<< >>Bayliner Fuel Tank Project<<
  #5
Old April 26th, 2008, 02:50 PM
4poco 4poco is offline
I used this stuff called, Quite Car. It is a liquid, all you do is brush or paint it in the inside of your engine lid. Every coat sound deadens by 3 db. Worked great for me, no insulation to worry about and it is fire proof. Makes your engine lid alittle heavy tho.... It is kinda like a rubber coating
.... I do have alittle over a quart left if interested?
  #6
Old April 27th, 2008, 12:32 AM
My cover is heavy enough as it is so I don;t want to add more weight. I am thinking about using styrofoam panels glued to the interior.
there is more than enough room in mine to clear all the engine parts.
any thoughts about using styrofoam? On another forum they talked about using the pink kind like you use in home insulation. It would be cheap and if it deteriorates you add more very easily. It is more for sound deadening than heat insulation on the engine cover.
__________________
"SeaDog"
AQ125a/270
  #7
Old April 27th, 2008, 08:59 AM
gcboat gcboat is offline
In reference to the pink insulation - how do you plan on applying it? Styrofoam doesn't like glue - it just melts. Plain ole' gas will destroy it. Here's a link to some good material. Probably pricey ( remember it's boat stuff ), but pretty much top of the line:http://www.acoustiblok.com/marine.html.
Do a Google search for <marine insulation / engine> there's a bunch more.
  #8
Old April 27th, 2008, 02:47 PM
Ares596ZP Ares596ZP is offline
The only thing I would recommend if you do decide to go with an automotive deadener. Do not get one that is asphault based, they melt and turn into a nasty pile of goo. It is pretty messy to clean up and I imagine cleaning chunks of asphault off your motor isn't your idea of fun. Look for one that is all rubber. They are a bit more expensive but lasts longer and no mess.
  #9
Old June 1st, 2008, 02:15 PM
Rob454 Rob454 is offline
Go down to a A/C or contractor warehouse and tell them youre looking for the foam sheets that are used to cover Air conditioning pipes. the foam is about 3/4 inch thick and it has a self stick back. they come in big sheets
Thats what I would use
Rob
  #10
Old June 2nd, 2008, 01:27 PM
Rob I found something like that at Lowes, by Frost King. Works OK, adhesive is not good despite the spray on stuff I used so I threw some staples into it. We will see how it holds up. Price was right though.
Joe
__________________
"SeaDog"
AQ125a/270
  #11
Old June 25th, 2008, 09:10 PM
SKEETR SKEETR is offline
To reduce sound you need to disrupt or keep the noise from transferring to the hull or engine cover. I used carpet pad as it takes spray on glue pretty well. Sandwiched a piece of lino in between two pieces of pad for a sound barrier and on the inside glued a layer of paper backed foil flashing. Not too expensive since a lot of the material was available on the jobsite. Reduced the noise of my jetboat by at least 3/4.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Motor cover insulation- What is it's purpose? valbonski Force & Chrysler Outboards 3 April 1st, 2006 09:01 AM
85 Hp Cover Insulation & repair manual MWBROWN Force & Chrysler Outboards 2 February 17th, 2006 03:20 AM
Soundproofing for Engine Cover? krivnalyendi Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 28th, 2005 09:59 AM
insulation for outboard motor cover? fsutim Johnson & Evinrude Outboards 8 May 20th, 2004 03:13 PM
insulation kit for boat motor cover Twolaketramps Force & Chrysler Outboards 4 September 18th, 2002 05:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
